What's this !??
- Thread starter Guest
andymorris
There are no warning lights on the speedometer itself, but on the temp/fuel gauge to the left you have the brake pad, and handbrake warning triangles. On the oil pressure/battery gauge to the right you have the brake fluid and ABS warning triangles
"Central Warning Lamp
The central warning lamp is lit until the engine is started. This lamp monitors all functions shown on the instruments. Should one of these functions develop a fault, the central warning lamp comes on, accompanied by the relevant warning lamp. Both lamps remain lit until the fault has been rectified. The vehicle should be taken immediately to your nearest authorized garage."
I assume this means that you should have another lamp coming on at the same time which maybe is not working? Check what lights come on with the ignition in daylight and see if they are all working, like, for example, the brake fluid warning light. That might narrow down the problem, but others here are way, way more knowlegeable than me. enjoy your 944.
pauljmcnulty
In the fuel and temp dial there's seatbelt man centre. Above him a triangle, above that brake pad warning. Below him is a triangle, then handbrake warning. Very top has warning lamp for towing....not used that one yet! [&:]
In the oil and amps dial there's a triangle at the top with brake fluid warning below it.
Failing that, could you photograph it? Or, I can scan the page of the handbook and e-mail you. I am the IT expert on this forum as well [
John Sims
PCGB Admin
ORIGINAL: pauljmcnulty
......Or, I can scan the page of the handbook and e-mail you. I am the IT expert on this forum as well [][
Go on, say yes, then we can run a sweep stake to see if he can. [
hotblack944
pauljmcnulty
carlmthompson
That's the one cheers buddy i thought i was loosing the plot there thinking nobody bellived me [ORIGINAL: hotblack944
Every day is a school day...
