944Fripp
My S2 has after 110,000 miles had a new clutch. However it has been in the garage for 3 weeks because the new clutch slipped! It's not a specialist but it is a reputable garage, the clutch and kit is OEM and the engine is completely standard. After a second new clutch it still slips. It occurs when you give it the beans and is most noticeable when changing down to 3rd at around 50-60mph. Revs hang at around 5,000rpm but acceleration does not occur for a good second or so. No slip is to be found lower down the rev range at all, it feels as torquey and responsive as ever.
Is there anything else that could cause these symptoms other than a worn/incorrectly fitted clutch?! Slave or master cylinder perhaps (although I've not noticed any fluid leaking the pedal has a tendency to sink when stationary for any length of time; this is not a new thing and the reason for it has never been found despite numerous attempts)) or maybe something in the transmition? S2's aren't fitted with an LSD are they as this my need looking at? Anybody got any insight?!Thanks in advance.
