What Suspesion Upgrades...?
Uniball between trailing arms and rear axle
Delrin bushes on spring plates
Old standard rubber bushings on the rest
Everything standard at the front
Car very much lowered (too much according to the guy who adjusted the car, who said it was a pain to get right, and he is a KW dealer who had done tens of cars before)
To my surprise it wasn't anymore noisy than a standard car.
It wasn't before I gave the wheel back to the owner that he mentioned these mods, but yes the car drove like a real go kart. In comparison my turbo drives like a rotten stick of wood, even on KW V3 too...
ORIGINAL: Ex Skyline
Like it say's on the tin. I am taking the Turbo back to JMG next week to get the KW V3 suspension fitted and the geometry set up before we head for the Nurburgring in the middle of May
Pete, how are you getting on with the KW's now? What stiffness are they set to and do you find them too hard for roads with poor surfaces? I am considering the same shocks but purely for road use. I have heard they will be firmer than my M030 Konis but will ride the road surface better
Bob, I have kw's on my S2, I've not had the m030's on my car so can only compare to stock. The kw's at their factory settings whilst firm are a good compromise between compliance and improved handling. Although how the car drives on a and b roads will also depend on how the geo is set up after fitment. My advice would be to start at the kw factory settings and if you find it too much for the roads you drive on, adjust out a click to 2 and try again.
If CG are doing the fitting for you, he will let you try the settings first on a test drive and adjust to how you want them to be. He will also set up the car for a + b roads during the geo, for fitting the kw's he is difficult to beat.
Edd
Hi guys, don't get the car back until Thorsday afternoon when Jon is bringing it to me before we set off for the "Ring"[8D][:D]. Went for a full on, total rebuild of all the suspension and braking system in the end [8D],Can't wait to drive it!![:D]. I will give you the full run down on what has been done and how he drives next week on our return. There's Jon Mitchell and I going in my Turbo and, my mate Frank (another garage owner from Saltdean) and, a friend of his are coming in Frank's 996.Should make for a very good long weekend! Joined ADAC last week just in case but, hopefully, the Turbo will do the bizniz and, all will be well [:D]. Next on the list?.........Total Head job!!! Skimmed, ported, polished, gas flowed, valves, guides, springs, Schrick fast road cam and, a partridge in a pear tree!![:D]. Watch this space!!
