what are the things to look out for with an s2
- Thread starter Guest
The interior is a lot different to an 84 car, look out for the usual dash cracks, worn seat bolsters, gearstick and steering wheel. The electronic heater unit can cause some problems so make sure all the settings and temps work, some fixes are cheaper and easier than others. The clocks tend to not work, but are expensive to replace so most people don't bother. Make sure the central locking all works, and that the doorlock pins flash when the alarm is set. They have red LEDs as standard, and can cause problems with aftermarket radios as some of the loom is wired through it. The usual checks for sunroof leaks and electronics still applies too.
The front wishbones are cast units with integrated ball joints unlike the early cars and are not supposed to be rebuildable, although some companies do offer this service now. New ones from Porsche can run to £400-500 each, and some of the rebuild kits have poor quality reports, only lasting a year or so. Check for play here very carefully or you might be in for a nasty bill.
There are quite a few more small differences but I think these are the main ones I can think of right now. Like the guys say, do a search and read some of the other threads as they may provide some different info
Hope this helps
Rich
