SimonExtreme
The class in which I race my 964RS is based on a power to weight ratio and I am at the "wrong" end of the scale. I can either gain more power or lose weight. The next stage for me with power is MoTeC, heads, cams etc. and therefore I am first looking at losing weight and I can lose 100kgs and still be in class! So far, compared with when I was weighed, I have removed the following.
Front mats, carpet and foam 6kgs
Spare wheel and jack 14kgs
Passenger 4 point harness 2.5kgs
Old unused "tracker" system 1.25kgs
Replaced standard battery with race battery 5kgs
Total 28.75kgs
We have also found that, much to my suprise, the car feels really good with a low fuel load so I will be running with about 15 litres less fuel. That is another 11.26kgs saved making the total so far a rather useful 40kgs. For some reason my car weighs rather light, considering it has a half cage and power steering. Even without the fuel saving, we are well below 1200kgs, heading into N/GT territory (just for Des[
Where should I go from here. Please remember that this is also a road car which I use almost every day and I want it to look as original as possible. The idea is to spend as little as possible or at least get VFM. To illustrate, the 5kgs for the battery cost £200 or £40 per kg. This is really good value. However, I have ruled outr changing seats because the RS seats are so light that to get a noticable difference would cost £350 per kg
All ideas welcomed!
Total 28.75kgs
All ideas welcomed!
