now the weather is improving we are going to bring the beasty out for some work.
before we put her away for the winter there were a few issues that we need to look at.
1) engine doesn't turn over.
done some investigation and I think the battery is duff so I'm gonna start with that purchase first.
2) intermitent reusal to fire up with engine turning over.
no needle movement so gonna replace the speed and crank sensors.
3) a new problem appeared late last year. overheating.
so my questions are based on the water system this time.
firstly which way does the water flow through the system?
i.e. does the water flow from the top radiator hose through the rad to the bottom hose, then into the water pump?
or is this the other way around?
could an air blockage in these engines cause overheating?
what is the best series of tests to diagnose an over heating issue.
The problem
driving at 30-40 mph there is no overheating problem at all.
stationary the temp needle just keeps rising alarmingly.
the fan kicks in at the required temp, but there is no difference.
There is no thermostat on top of the engine, is there more than one?
any help is greatly appreciated as I am still unfamiliar with this car.
The problem
