This is Fixed now - turns out small hole in a metal pipe - Now needs Oil Cooler
My 996 is down in Aberdovey at present with a Water Leak from the front of the Engine (Near the Top)
Guys have got it leaking but just need to work out where its coming from
Went to Porsche Wolverhampton only to be told its leaking from the top of the engine Not really any help as they would not give me any idea of how much it would cost or what it was - That cost 85.00 - Not impressed
F1 in Shrewsbury had pressure tested it and could not get it too leak - but did inspect all the lower hoses and said the where pretty sure they where OK
Apparently the hose clips do loose tension and can leak under pressure - Everyone recommends using normal high quality clips and I think the Porsche replacement ones are standard now. Just checked the replacement clips from Porsche and they are "Standard" screw type clips - INTERESTING!!
As a matter of interest does anybody have a schematic which shows all the pipes and hoses - preferably with the engine and gearbox
I have PET but it give no real hint of where they attach to the engine gearbox
My leak is a really interesting one - It takes about 2 hours of pressure/ running before it starts leaking.
Lost 2.5 litres of water driving down to Dynas Mauwdy ion Wales from Shrewsbury hoping its just a clip of pipe!!
