water in n/s footwell
- Thread starter ocallen
Blocked sunroof drains is favourite though!
Mike
Is it wetting the front carpets or rear carpets?
If you have a sunroof, try the drain tubes. You have to remove the roof and you will see four drain holes. 2 front and two back. Pour a little water in each hole and see if you see the water coming out from under the car. If not use a little strimmer wire or similar to thread down the hole to clear it.
If its not from here, open the bonnet and clear any leaves etc out from the front of the engine space - where fuse box lives.
Report back and i will try my best to help.
If its not these then try looking at the windscreen seal - i read on this forum that these can weep, letting water into the front footwells. This would show by the carpet close to the front seats being wetter.
ETA: I also read that the gromit and water pipe inside the fuel filler area can become detached - letting water into the inner sills and ultimately into the car itself.
May also be the rear screen hatch seal as this comes over quite a long way into the car. Almost above the rear seats. Check this too. This would show by the back seats carpet being wetter...
Report back - Im waiting for the rain to stop in conjunction with the weekend so i can stop my water ingress.
robsangster
