WAKE UP!
- Thread starter Sam Quick
Yep, tried that and the ignition, is there a porsche article on the subject?
Yes, it is in the handbook.......
As Tony says - turning the key in the ignition will wake up the system.
Are you sure the battery isn't flat?
thirteeneast
Sam Quick
when your too late with the key in the ignition and the alarm goes off - with the key then in the ignition and pushing the remote button does switch the alarm off, but cant open or close the doors.
also do apreciate the quick response from the last post but wont just dismiss it as simple as that as theres always a reason and always a solution.
cheers
thirteeneast
It may seem a quick response but Ive been down this road with a couple of my keys in the past and one that was reprogrammed lost its programming a couple of month's later.
both are no good for the alarm but the RFID chip is still ok for the immobiliser that works of the antenna ring on the ignition.
thirteeneast
If anyone knows it would be them although i think they can only programme the RFID chip (the little brown capsule thing that lays next too the key blade) not the same as programming the alarm side of the key.
Its worth checking the solder joints of the key as there are not very good.
To be honest I wouldn't worry about it too much they still operate the central locking and start the car and now days if an alarm does go off who pays any attention.
