991.2 GT3 needed a VTS hard reset after it stopped responding. Dashboard out to get at it, leapt into life, let’s say £1500 but under warranty. Now, it’s happened again with 2 months warranty left to run.
What’s amazing is that taking the car onto the Isle of Skye, to the same location, appears to have initiated the failure in both cases. In the latest situation, the last known position was a car park where the position of the car is correctly marked but now the car cannot be contacted. It’s as if taking the car to that specific location has caused the software running in the VTS to hang up and only a hard reset (which I believe is a power cycle with a magnet held to the side) will fix. Problem is, on a 991, the VTS is mounted on the front firewall and the whole centre console and dash has to come out to get at it.
I can get it reset again under warranty but then what? Trying to convince the dealer that a hard reset is simply papering over the cracks is going to be difficult.
