I've attached below my Air Fuel ratio from the Weltmeister DynoDay and you can see that I am running pretty rich with an AFR of 12/1 at 3300rpm falling to 10/1 by 4500rpm and climbing only to 11/1 by 6200rpm. Am I correct in thinking that an ideal situation is around 12.5/1 during boost, with a little leaner at the start (say 14/1) to help spool up
I actually had my boost set to 16psi for the run because I knew I was a little rich at the 15psi I've been running for the past 15k miles.
Apart from a remap or MAP kit or MAF kit I'm thinking of a stopgap solution by removing my 3 bar Fuel Pressure Regulator and reinstalling the standard 2.5 bar FPR and running at maybe 14 psi which will hopefully see me get back to an AFR of around 12/1 whilst I'm on boost. This will remove any danger of bore wash by the excess fuel, save me fuel costs [
] and probably give me more power, as running that rich is robbing me of horses.
Comments?
Comments?
