daviespaj
Ok, I haven't had much spare time as I am working from home, but did manage to finally get the engine and gearbox mounted on to stands for cleaning and refurbishment. Getting the engine though a single door into my workshop from the garage proved a little tight. Unbolting the inlet manifold and rotating the engine did the trick. I will do a whole lot of cleaning and strip the engine accessories off ready for a rebuild. Probably will use Ninemeister for the rebuild? I did consider trying to rebuild it myself (I am an engineer and have done a number of 'normal' engines in the past). However the Porsche engine is not quite like most standard engines and I could cause a whole heap of trouble if I get it wrong!
