URGENT - COOLING FANS ON
- Thread starter Guest
All help appreciated, even in locating the relay itself.
ORIGINAL: Fen
Ahh, one of my fans didn't work hence only needing to pull one fuse.
I don't know where the relay is, but it's usually the £20 switch that goes. I think unplugging it will tell you if it's the switch as it completes the circuit when hot and fails to that state.
Thanks, next question then - where is this switch you are talking about ? [
slim and i had a good look for the thermoswitch at the back of the radiator/fans to no avail tonight.
ORIGINAL: 944 S2
ORIGINAL: Fen
Thanks, next question then - where is this switch you are talking about ? []
Yip not a sausage!!
I 'think' you can see it on an S2 if you look down through the engine bay, but if not then take off the undertray and look up. It's basically a wire with a plug connecter onto the switch which is screwed into the radiator. Pull off the plug and if the fan stops then it is the switch that has failed. Changing the switch means draining the coolant and refilling/ re-bleeding the system [8|]
mik_ok
ORIGINAL: 944 S2
now this happens today after an amazing run in it
Not much help to you, but I had a superb run the other day too. Gorgeous sun, not too much traffic, sunroof open and plenty of grip available. Luverly. [
You, me and the the sliminator need to meet up again sometime late June / July. [8D]
will get peter to sort it out for me, need to get the cam chain / tensior, hand brakes shoes done soon anyway - just bring it all forward a couple of months.
defo meet up, might just be 2 944's and 1 civic [
P.S. Thanks Diver944 for confirming that, will check it before i get peter to do the work. [big thumbs up]
You can test the switch as described in Clark's Garage. Other item is don't over torque the new switch. The radiator end tanks are plastic and the thermo fan switch screws into a brass boss cast into the left plastic end tank. Crack that plastic and you just increased repair cost over 10 fold.
ORIGINAL: IceShark
It typically is the radiator thermo fan switch that fails. Better hope so because the main relay is quite expensive.
that'll be the ones advertised at £150 [
i am still to check the switch by pulling it out, off to check that guide you mentioned. I will defo be getting a pro to fit this item as i have other things to get fixed that i dont have the time/experience for.
Big thanks for the help so far [
ORIGINAL: Fen
The car will be fine at speed without the fans though.
Better get em fixed fast then. [8D]
ORIGINAL: Rodders
The wise thing to do is to pull the relay in the fuse box, then put it back in when you want to drive it. It only takes 30 seconds and at least your car won't overheat. That's what Hartech told me to do when mine went horribly wrong and set my alarm off in the middle of the night.
While I've done this myself it probably isn't the smartest idea to do this for long. The pins the relay plugs into weren't designed to take constant plug in and out and you don't want to be messing with them to replace or tighten up.
Another point is you don't want to stress the relay too much. It has a finite life cycle. Best to sort the problem sooner rather than later.
