Updated 997 may get Night Vision ?
Sundeep
Could the next version of Porsche's flagship model, the 911, be getting night vision? This might explain those square units (concealed within the headlights) on this photo of a facelifted 997.
Mercedes introduced night view assist, for the S Class. That system operates off two infrared projector beams mounted in the headlamps, and a camera in the windshield.
The Porsche system could work along the same lines.
I'm thinking of ticking the box for Night Vision on the BMW 5 series that I'm about to order.
It's not a very 911-ish option, though, is it? Race heritage and all that....[:D]
Logistically, where would the 'viewer display' for night-vision actually go?!
Mercs have it as part of a digital dashboard. No way would a facelift 997 have a digital dashboard, that's way too extereme a change for a facelift. Perhaps the 998!
Any integration with the PCM would be crazy as it's so far away from your field of vision that it would be more danagerous to look at and not a safety feature as intended!
That leaves a heads up display, but again, too extereme an introduction for a facelift.
So I reckon it got to be 'dynamic bend lighting'.
ORIGINAL: BLONDELAWMAN
And what's Dynamic Bend Lighting??
I assume it's the same as the Mercedes implimentation...
Headlamps following the car driver's steering movements and swivelling to the side as soon as he steers into a bend. This means that the range of the dipped beam light in bends can be increased by up to 90 percent: where the area usually illuminated when driving into a bend with a diameter of 190 metres is around 30 metres, the new headlamp technology extends this by a further 25 metres. Since the beam pattern corresponds to the respective steering angle, the driver can recognise the course of the bend early and adapt his driving style accordingly.
ORIGINAL: Alex L
Is this what the Citroen DS had in nineteen sixty-something?
Bit off track but those "toast rack" side vents at the front might look OK, but will make it difficult to clear the rubbish/leaves out of the radiator openings?
