TYRES !!
- Thread starter dgrewar
Copperman05
Or if you want the Porsche recommended tyre for your car then here.
Edd
Copperman05
Edd
Hilux
If the car has non-standard wheels then theres no reason that I can think of to worry about N ratings
What is it with peoples fascination for Porsche N rating on 25 year old vehicles!!
Why worry about it, its the size, load and speed rating you need for the wheels and car you have thats all - whatever else is up to the individual.
Porsche`s N ratings are recommendations and only that or you`d all be fitting the original tyres if they were in manufacture (not) or scrapping the car.
What ever. I rate Falkens as well and a much better/cheaper option than Conti's.
andy watson
Moderator
So to sum up......
18" wheels on a 944...a real no no!
P6000 tyres...a real no no!
Nothing like bucking the trend [
TTM
Well-known member
It may less be critical these days as most performance cars run (very) low profile tyres but that is not the case when most of us are still running 15" or 16" tyres. The higher the tyre profile, the quicker the issue may arise.
Copperman05
Edd
TTM
Well-known member
ORIGINAL: Copperman05
Porsche recommend N tyres specific to each of the classic models including the 944 as per the link, which I assume negates the only for 911's assumption?
... or which may confirm they may be as important on 944s as on 911s? [
Hilux
What happens when you go to 17" wheels, stiffer ARB`s and springing, 968 castor mounts and modern rubber and tyre sidewall design?
Copperman05
ORIGINAL: Hilux
I have no idea, go by the recommendations for the 968 if that's a more accurate comparison?
Edd
TTM
Well-known member
ORIGINAL: Hilux
What happens when you go to 17" wheels?
Porsche issued a note in 1993 :
http://www.asarus.com/jantes17.shtml
Copperman05
ORIGINAL: Hilux
I just re-read this, the recommendations for the 944 and other older models as per the link was published in 2011 and includes modern rubber that is available now.
Edd
