Tyre pressure monitoring 911 turbo
- Thread starter Hardy911
There are various types of wheel electronics available.
The fundamental difference is in the TPM generation (1st generation up to 2008 model or 2nd generation from 2009 model onwards) and also in the frequency (433 MHz or 315 MHz).
1st generation TPM wheel electronics up to 2008 model are not compatible with 2nd generation TPM wheel electronics as of 2009 model.
If wheels with 1st generation TPM wheel electronics are fitted on a vehicle with 2nd generation TPM wheel electronics (or vice versa), the TPM system will not recognise the wheel electronics. The TPM system is not active and a corresponding warning message appears in the instrument cluster. In addition, the wheel electronics are reported as defective in the fault memory of the TPM control unit.
