Can anyone suggest appropriate rear tyre life on a 933. I run 18" Michelins and with merely spirited road use get 4000 / 4500 miles out of the rears. Wear is pretty even, a little more towards the inner that the outer as you would expect from the negative camber it runs as standard. Wear is marginally harsher on the nearside. Geometry has been checked and is good.
I do about 5k to 8k miles / year. Is there a better choice than Michelin for durability?
Thanks. Tony
Thanks. Tony
