Tyre advice - stick with Pirelli or switch
steven.adcock
Hi All,
I’ve recently bought a 991.2 C2S and I’m loving it!
The only issue is that in the wet, the back feels quite unsettled and I’ve lost the back end on roundabouts at low speed, with limited power/revs.
I’ve got a new set pair of P-Zero’s on the front and the rears have 4mm of tread left. Front is really nicely planted and no sense of them not coping when the rain is really coming down.
From doing a bit of research, most seem to prefer Michelin PS? Better grip in the wet? Are their different Pirelli’s to fit, like an all-weather version anyone has experience of?
Any thoughts or advice?
Thanks!
Hi
Firstly if the car is not feeling settled at the back then its worth inspecting your dampers to see if you can see signs of any leaks. Rear dampers wear and will need replacing at some point.
On the tyre front. The P Zero is total ****. Compared to a Mich PS4 (and probably the new 5 which I think is now available to buy) there is no comparison. With P Zeros the ride is harsh, lots of road noise and the steering heavy with little feel. Change to PS4's and all that changes. Smoother, quieter ride with lighter steering. Change to Cup 2's and those traits get even better, but then it will be a nightmare in the wet and you will get punctures. I went from P Zero to Cup 2 to PS4 with my .1 GTS, used as a daily and on track. The PS4 is definately the best allrounder. The only negative to the Michelins is that on a motorway run the mpg will drop by about 4mpg.
Thanks for the advice. I only got the car in Sept from a Porsche dealership and recently checked out again when I can a vacuum leak so dampers should be all fine.
Your advice and experience aligns with some of the other views I’ve read on PS4. Looks like I’ll be making a switch soon.
Thanks for the prompt response!
If you’ve got the older P-Zeros I’d recommend the current PZ4. I’ve had the PS4S on a previous 718 and have the PZ4 on my current 718 4.0. The Pirelli’s are much more compliant as the side wall is a little stiffer.
Dan.
I find the PS 4S best for mixed conditions on 991 and 992 models that I have owned. The P-Zeros were always relatively nasty (although I haven't tried the PZ4). Continental SportContact 7 might also be a good option if you can get N0 in your size.
Hi All,
Thanks!
Steven,
I suggest that you check the manufacturing date of the tyres which is printed on the sidewalls. If you bought it from a Porsche OPC, the tyres should not be over 5 years old.
I had the same problem with my 981S and discovered that the rear tyres were old. The dealer replaced both at no cost to me without any argument. The new tyres transformed the car.
Out of interest, the replacements were P zeros which I find excellent. The latest versions are much improved over the previous ones so whilst PS4's seem to be the preferred option, I would not discount the Pirelli's.
Steve
Just don't get PS4 mixed up with PS4S. Completely different tyre. Added confusion when people use PS4S to mean the plural of PS4.
I have just bought Michelin Pilot Sport 4 S (N0 rated) for my 991.2, front and rear. (I hope they are the right ones given Briggy's comments above!!)
I did have P Zeros on before (came with the car when I bought it, and they were very worn, but still legal, just).
Ordered the tyres through Blackcircles, and got a good discount (£200 I think - but not sure).
I went for those based on countless reviews, watching You Tubers, and asking here on the forum.
I am, pleased with them - but cant really tell any difference yet!
In the latest Chris Harris You Tube video with a 992.2 turbo - he keeps moaning that the car had Pirellis, and not Michelins - so I must have made the right choice!!
Hi Steven,
Whatever the merits/demerits of the Michelins over the Pirellis and vice-versa [and everyone will have their own opinion on this!], since you have a new set of Pirellis on the front the logical route would be to replace the rears with the same rather than going to the expense of replacing all four tyres.
In addition, as well as the possibility of getting a discount on the tyres from a provider such as Blackboots, etc., if you’re a PCGB member you can claim a rebate from Pirelli [up to £120 by BACS transfer] when you purchase two or more tyres from a participating dealer.
Jeff
