I have an issue with the cooling fans both of them intermittently coming on even when the car has been parked for a while and the engine is cold. I have removed the cable from the thermal switch on the radiator and the fans keep running. This would suggest that the problem is with the relay? Can anyone confirm that this is a correct assumption?
As the relay in question is £135 I want to be sure that replacing it will cure the problem.
Does anyone know where I might pick up a cheaper one? So far I the best I have found is £135 on the type 911 website.
Many thanks for any info
