My turbo wouldn't start on Tuesday. It was making a bit of a grating when cranking for a couple of days. I thought perhaps the battery was a bit low. I think maybe the battery went totally flat. I d/c it to charge and now it wont even try and crank. Just like the immobiliser hasn't de-immobilised the car. The battery is showing 12.4 volts on a multimeter and wont take much charge from a battery charger. Before I start looking at ripping the immobiliser apart are there any relays/fuses I should check. I had a look on the fuse box but it doesn't list any to do with the starter motor. Any suggestions appreciated.
Looks like this might be a feature of the immobiliser. Any way to reset it? I think it might be an after market. Its got a key fob you push into a slot on the right side of the steering column..
