Turbo S lightweight wheels..
- Thread starter Big Dave
Assuming you mean Silver Rose forged wheels (because you already have D90's I assume) then the answer is lots. Up to at least £400. To be honest they aren't worth it on a track car IMO if only because it's far more difficult to find 16" track tyres than 17" ones.
I believe they only come in the one size combination but as I got it totally wrong last time I'm now confused as to what that was. 7.5" and 9" maybe? There was a 928 model that had them too, but those may very well have been the same size.
TTM
Well-known member
The design was adapted to the 1988 944 Turbo S with 7" fronts and 9" rears.
Some knob writing press articles once wrote they were made of magnesium, although they're only something like 25% made of magnesium. Since then thousand of naïve people have believed those wheels to be 100% made of magnesium, which is wrong.
Pedantly Yours,
Big Dave
Thanks for the info....
Actually i have a set of 17" cup 2,s fitted at present. + mighty fine i think it looks too....
I will post a pic when i get round to it....
I do agree with you about Track tyres are harder to find in 16" ...
Just a thought.........[8|][8|][8|]
mik_ok
ORIGINAL: mik_ok
and i believe the 928 used the 9"s front & rear.
Doh!
(Bows to thom's superior knowledge).
must....learn.....to.....shut....up....when....I....don't.....know.....the....answer
I'd like to see some definitive weights of these wheels without tyres because I have a set of each, D90s and Forged CS, and I'm not sure there is that much difference.
My D90's have Pirelli Slicks and my CS have Kuhmo street tyres yet when I weighed them they are identical. I am guessing that the track tyre must weigh a lot more, but I don't know for sure [&:]
Dave Sims website has some wheels weights (but not the D90s) www.944turbo.org.uk
mik_ok
Which is just plain greedy! [>:]
ORIGINAL: mik_ok
I won't mention the 17" Boxster twists then [
carlmthompson
hotblack944
ORIGINAL: Diver944
Try here http://www.wheelweights.net/
Jim.
uktrucks
Ex Club Member
IMHO not advisable stick with your std wheels or more modern 17"s
Allan
They don't feel any lighter to lift than the D90's when I pick them up, but are very strong due to the drop forging process... but, it makes them brittle in comparison the standard alloys. When they go, they go in a big way! Trouble with second hand wheels is you need to be sure how they've been treated in their past life to be sure of flinging them round a track.
Personally, I think they look the nuts on a pointy-nose 944 (like my S), but the 7.5 front and 9 rear D90's look beautiful on the later 944's. Or you could go to Cups...
The wheels have been refurbed at some point and judging by the faintness of the markings I'm guessing quite a bit of material was lost in the bead/shot blasting. I would certainly advise against using these wheels on the track unless you're sure of their history and will be replacing mine probably with D90s.
Tim's point about spacers doesn't fit with my experience. My car doesn't have any spacers. Are you sure they should have been fitted?
