turbo finally "finished" - but at a cost!
Ewan
I bought my 951 16 months ago, with a view to using it as a cheapish but fun daily runner. For a car with a pretty comprehensive service history file and lowish miles (94,000) it was quite cheap, but I did buy it in the knowledge it needed several jobs doing to get it through its then due MOT (such as new handbrake cables and new tyres) as well as being due a good service.
The list of MOT jobs grew (inevitably), but we got there in the end, having spent about £800. At the same time I opted for a big service, including plugs, filters, all fluids and a few smaller jobs such as a new battery, distributor cap, rotor arm, header tank cap, boot lock adjustment, radiator relay and thermo switch etc - which came to maybe another £800.
It was noted that the caliper slider plates were lifting (no surprise), so they were all done, for £500.
But the steering and handling were not quite right - so it was time for a new steering rack/pump/fluid, uprated (968) castor mounts and anti-roll bar bushes - at about £800.
I soon decided it was to be a "keeper" so decided to do an engine front-end job - new rollers, tensioners, belts, seals, waterpump etc - so that I could be confident the car would be good for a few more years yet. A further £1300.
In the first month or so of ownership I had therefore spent about £4200. Not ideal. But on the other hand I had done several jobs that would last a long time/mileage so would not need repeating anytime soon. I could now settle down to an extended period of enjoyable, cheap, Porsche driving.
Or not, as the case would be. A serious overheating issue meant a blown head gasket and a warped header tank. Worse still, a pressure-test revealed a crack in the cylinder head.
I discussed various options with Jon at JMG and decided to go for his 9XX performance head. To make, supply and fit this (including the head machining, and fitting of valve/cam/springs/retainers/fluids/seals/gaskets etc) the bill was £1200. Plus about £300 for a new header tank and coolant pipes.
Having bitten this bullet I decided to have some uprgades fitted at the same time. So in went the 9XX chip set, 9XX dual-port wastegate and boost controller, 9XX dump valve, 9XX fuel pump, 9XX 3 bar FPR, a boost gauge and a de-cat exhaust pipe. This came lot came to about £1600, but at least I had something to show for it (some shiny bits under the bonnet and about 70 new bhp).
The added power may have contirbuted to the fact that I then needed new gearbox mount, knock sensor and drive shafts, at about £800.
By the time we had sorted out a few further niggles such as repairing the heater, refitting the drivers door card, replacing the drivers seat switch, securing a heat shield, fitting new brake flexi pipes, fitting a new chrome exhaust trim and a new bonnet release cover, my total spend for "part 2" had somehow become about £4500. Hey ho. But at least the car was now sorted, and fast. Things were looking good. Right up until the point I decided that my Alipne white was no longer as white as it should be.
So off to the body shop she went. A re-spray and a refurnishment of the original Cup alloys and she came out looking a million dollars. Which, coincidentally, was about the cost. No not really. It came to about £1800 - which I thought was very good value.
Finally the car looked great and went quick. But the ride and handling still weren't as good the car deserved. Which bought up the old chestnut - whether or not to fit KWv3. After much forum debate I decided to fit new adjustable Koni inserts instead - a cheaper option that I have to say has worked wonders. Along with the new suspension and wheel realignment came a bill for about £1500. But worth every penny and about £500 less than if I had chosen the KWv3 kit.
And the £500 saving meant I could spend it on new tailgate gaskets and side panels and a rear Porsche decal.
Now we were really buzzing. And I mean that literally - there was a nasty buzzing sound from in front of the gear lever. This meant new engine mounts, and a bill for £600.
With the car now perfect I just needed a few sunny days. And when they arrived (about a month ago) I realized that the sunroof system was buggered. But its all sorted now, and I'm about £250 the poorer.
At this point I was confident I was good-to-go. So off I went. At speed, on a hot day. Which I have to say was brilliant - until I stopped. Because when I stopped, the car overheated and spewed coolant all over the car park. Hmmm.
It so transpires that the radiator was partially blocked/inoperative. Out with the old, in with the new. £700.
This spirited drive also highlighted the fact the front brakes that I thought were probably just about okay, actually weren't. New Pagid discs and pads and sensors supplied and fitted for £400. Bringing the cost for "part 3" to around about £5800.
So there we have it. If you want to know what it costs to have your local Porsche specialist reapir and upgrade a 1990 944 Turbo SE (MO30 spec), now you have the figure. It comes to about £14,500. Please note that these are approximate, and include Vat at 20%.
Of course, most of you clever chaps on here would have done all this work yourselves for buttons - but at least you can pat yourselves on the back and be happy knowing how much you've saved! But mechanics are not my thing - I'd rather be in my office earning the money to pay the garage. It's just what works better for me.
It should go without saying that this little journey is not the one I had intended to take. But when the garage door goes up, and the cover slides off, its all been worth while. And that's before I even get in and drive it. What I can say is that while the number of good 944's goes down each year, this one has been well and truly saved. And even if I don't keep it long I'm happy I've done my bit for the model.
(And finally, before anyone says it, no, I don't wish I had bought an S2!)
Good for you mate, when people spend £14,500 on a new car nobody bats an eyelid, when you spent it on a 25+ year old 944 people think your crazy. I look at 944 ownership as a long term restoration project with some ongoing big bills, looks like yours was done more in the short term!
Enjoy the car, you deserve it!
Edd
PS Yours isnt the Alpine white Daytona had for a while is it?
Well done. Take some comfort from the fact that YOUR car will be one of the nicest left on the road in the UK. It's no average 944T. Pictures when ready please....
(If you decide "not to keep it long" rest assured I'd be happy to buy it blind for £5k). [:D][:D][:D]
Now you see its always a mistake to actually add up what you have spent because its always a bit scary and should SWMBO see it it turns into a very expensive shopping trip!
It was looking good when I saw it so now it really is sorted it should be good for a while - still not convinced by the yellow piping!
And your new Italian arrival is bound to break first!
Ouch, but i cannot think of anything else you could repalce now, should be good for years.
As Edd said, you've spent the price of a Focus on restoring and vastly improving a proper car, with a huge amount of performance and character. Most people would expect the same work on a 1980s 911 to cost a whole lot more, with their perception of Porsche parts being expensive, so it's a shame anyone would not consider this money very well spent.
Mine's just gone in for a major service and belts. So far the only bad news is that they've discovered the problem with the vibrations at the rear is corroded axle mounting points. Whilst it's a nervous time waiting for the bill, it's worth every penny whenever I drive the car. [&:]
Well done that man, worth every penny I'm sure. I think it's safe to say that you have been well and truly bitten by the 944 bug.
Congrats..:)
Pete
Woohoo! So I'm not the only one who's gone overboard on spending to bring a car back up to scratch.
Just read the post again, you have spent in 16 months what has taken me 10 years!!!
You must be pleased, it is well worth it, yes?
Now all you have to do is enjoy
ORIGINAL: 944 man
Please explain 'finished' to me.....
Haha! Was also going to comment on that! No such thing as a finished 944. Just picked mine up from Project 9. Am approaching having spent the purchase price in 1st year of ownership and still lots to do before it's "finished"
I hope you can really enjoy the old girl now Ewan. It's good that you can spend that sort of money. Not an option for me but that it is part of the fun doing it all myself. Well most of the time but the odd occasion I do feel like fetching the petrol can [:D]
Yours running yet Rob ?
You always think they are finished then this bloody forum plants another seed in your head [:D]
Digital AEM boost gauge next methinks and uprated suspension for the 220 [;)]
Great story... although sounds like you've had more than your fair share of bad luck along the way. I hope you get a good few fun and trouble free years out of her.
Not yet Jim. I am waiting on a couple of little bits from Alasdair and a new water pump to rigid heater rail hose from OPC Cambridge arriving. Have had the kids most of half term as well so not got anything done. Fingers crossed she will be running by next weekend and I can start the running in process. Well static at first as it still needs to come off SORN.
I've suddenly remembered that it's not actually finished. There is the little issue of the clock. In a completely out of character moment of DIY enthusiasm I bought a new clock screen from Alastair for a very reasonable fee.
But it so turns out that it won't fit itself. So it still in it's small bag. And given that I wear a watch, and carry a mobile phone, the dash board clock has slipped somewhat on the priority it front. Hopefully one day I'll have someone fit it for me.
Apart from that, it's finished for now.
That said, Jon tells me he has an immaculate Can-Can red leather interior in storage. If I get bored of my Maritime Blue interior, I do fancy the bright red option. Though i suppose that would mean new carpets as well. And where would that leave my dark blue dashboard? Will it ever end...?!
