Turbo Engine Rebuild
- Thread starter scam75
Air Pressure Regulator Adjustable Pressure Relief Regulator with Gauge- | eBay UK
scam75
Well-known member
Before you get rinsed for a Lindsey (Or worse 9XX) MBC - be aware it’s just a cheap air compressor adjustment valve similar to this one (adjustment ranges vary - I think the 944 used ones are 0-100 psi hence you need safecraclears fingers to go from 15-18psi):
High precise pressure gauge-, precise pressure regulation, strong pressure resistance. Adjustable Pressure Ranges: 0.05-0.85Mpa(0.51-8.7kgf/cm²). Max-Working Pressure: 1.0Mpa(10.2kgf/cm²). Note: Also Have the pressure regulating ranges 0.02-0.2Mpa(kgf/cm²).www.ebay.co.uk
Thanks. Got one alleged "UK stock", £7.49 delivered. Will do for the purposes of eliminating a faulty MBC.
scam75
Well-known member
I turned the original MBC fully down and still no boost control. I'll replace the MBC when the new connectors arrive, if that doesn't resolve it then I have mystery wastegate problem which makes no sense as we opened it up and checked, cleaned everything, put in a new diaphragm, and all looked good, no cracks, valve was perfect. Hope the MBC is to blame, if not I am puzzled.
I will pull apart the old MBC when it is off, if it has disintigrated possibly some debris in the MBC to side port line? Fook knows..........getting quite used to using my right foot as the wastegate now.
blade7
Well-known member
When you consider what it costs to repair a KLR or DME, or buy a new TPS, if any of them start playing up, something like VEMS plug and play makes sense.Good luck sorting the problem out, I'm considering an EBC for my car when it is up and running again. But even a second hand one is around £200, then you start wondering if it is worth saving the money and purchasing a full aftermarket engine management system.
scam75
Well-known member
£7.50 for the controller, £6 for 2 brass fittings and £1 for PTFE tape. Mustn't grumble at that.
Cheers to Eldavo for the heads up on the boost controller. I'm going to buy half a dozen and get some 9xx stickers put on them and sell them for £199 each........
Edit to add - the controller I bought is an AR 2000 and I had to buy 2 x 1/4 BSP 6mm male elbows to fit it.
blade7
Well-known member
This is what happens when you insure old bangers for £30kThere sure is a lot of robbery going on with greedy mark ups for the unsuspecting among us.
Need to up the agreed value on mine thenThis is what happens when you insure old bangers for £30k.
scam75
Well-known member
scam75
Well-known member
The boy now knows lefty loosey and righty tighty! Small steps............
Edit to add: they are handbrake adjusters, not self-adjusters, doh! Couldn't quite fathom how they would "self-adjust" anyway..........
MOT passed, no advisories, always good! 4 more to go before exemption. 2.5% CO and 50 HC, happy with that, engine seems happy.
All sorted for road trip now, leaving next Saturday!![]()
CO is quite high?
I documented my readings from previous MOTs as my last MOT only just scraped through the limit.
I bought a Gunsons gas analyzer to test it once it is back together.
Most of my readings were around 0.50 % CO apart from 3 readings above 1 (1.746, 2.43, and 3.104), HC around 50 apart from the two high CO readings where it was 140 and 165).
High Co Emissions - Rennlist - Porsche Discussion Forums
Yes - possibly running a little rich at idle, are you still using the scivision MAF or have you swapped it out to a standard AFM now?Noticed it was 0.9% last year. Maybe machine calibration or something, not concerned. You are allowed 3.5% for MOT.
scam75
Well-known member
I can only go on AFR's however it idles at mid 14's now so it doesn't seem rich, and the AFR's across the range are spot on.
One small issue I have, and haven't been able to sort so far, is that warm idle is nearly 1.1k revs, cold idle is normal around 850/900 rpm. TPS possibly but it seems to be working and clicking when it should as you can see fueling stops off throttle (AFR gauge shows this) and recommences for idling purposes.
It's been like that since the engine build 2 years ago.
Edit to add - with the aircon switched on, warm idle is pretty much back in spec, so it's a head scratcher!!
