blade7
Well-known member
I use a AFR gauge, with one lambda sensor mounted in the downpipe. Though that doesn't tell you if one cylinder is running leaner than others. I think you're taking a chance running 18lbs or more on standard injectors, whatever gear you're in. I read a report that typical £200 AFR kits can have up to a 10% tolerance. I'd perhaps take that chance because I've got a back up plan in place, I definitely wouldn't if I'd recently rebuilt my engine due to a piston/cylinder issue.
