Hello chaps,
My turbo is going to Northway to have the belts retensioned after they were changed at the last sevice. Having had the car a few months I was wondering whether to ask Northway to have a look at the following points, but don't want to ask if they are normal mannerisms from a turbo, so here goes: (god that was a bit long winded![8|])
1.Getting off the gas at any speed, but particularly at lower speed is a very jerky affair. A bit like an on/off switch, no matter how careful I try to be lifting off the accelerator. Normal behavoir from a turbo, or something that can be adjusted?
2.I have a bit of an oil leak. (Pressure is spot on)
3.Steering seems a bit heavy (original wheels, a replacement 2nd hand power steering pump was fitted at the last service)
4.Turning the steering at parking/manouvering speeds is stopping the belt from running (the belt that is parallel with the front of the bonnet. Sorry, I'm a wiggy mechanic) but runs OK once steering movement stops. I'm hoping this one will be sorted with the retentioning.
Thanks in advance for any advice.
