So there is!
However, I can't see how that can work properly.[8|]
Let me explain why I don't see this so someone can educate me....
The MBC is simply a pressure regulator which sets a limit to the amount of pressure that is passed downstream. To the WG in this case.
The single port wastegate will open when it receives sufficient pressure in its cold port to compress the spring in it's hotside.
So, the WG needs to open when pressure rises ABOVE a certain point and the MBC is designed to keep the pressure signal BELOW a certain point. Surely this is a fundamental missmatch......
Lets say for example that the WG will open when it receives a boost signal of 7psi.
If the MBC is set at 5 psi and you spool up to boost of 2 psi, the full 2 psi gets passed on. WG stays closed.
At 4 psi, 4psi gets passed on. WG stays closed.
At 5 psi, 5psi gets passed on. WG stays closed.
At 7 psi, STILL only 5psi is passed and the WG STILL stays closed......
Boost now rises to 20 psi, the WG still only sees 5 psi and so STILL stays closed........[:-]
For an MBC to work properly on a standard / single port wastegate, the above must be incorrect. Why???
Confused of Barkby.
Confused of Barkby.
