craiginuk
Frustrating day with the car today. Bled the cooling system again as I think there is still a bit of air trapped since changing the thermofan switch on radiator. Anyway, tried to run a pipe from the bleed port to the header tank by using a bleed nipple instead of the normal bleed screw which worked well. Pipe ran clear after about 20 mins. Then rmoving the pipe to put the normal bleed screw back in things got a bit messy and hot ie burnt myself. Loads of coolant came spurting out before i could get the screw back in. Could that suck air into the system?
Carried on with the normal bleed screw and it seems to be ok. Then when i got home after a test drive the turbo circulating pump didn't kick in. Should this always run after the car is started irrespective of temperature etc?
Sorry for the grbled post - just a bit fed up with it all as i feel ive made it worse...
