What are the options?
Iv read a lot and not really got a great understanding off it all. I phoned Jmg about month and half ago still awaiting a call back. I understand Jon not very well and Iv still not got the car back 2 test out the last bunch off upgrades, due to some sill work.
But Iv just been offered a kkk27 £300 delivered
Specs
This was built with a brand new turbo with ported compressor shroud, it has had a Ar.58 exhaust housing fitted for quick spool and the turbine blades cut back and the re balanced. It is also journal bearing.
The wheel sizes are.
Compressor wheel:
Inducer 55.72
Exducer 82.43
Turbine:
Inducer 60.64
Exducer 69.82
Only thing is hot side is t3 fittment is this the mount to exhulst
Iv got a 3" fab speed down pipe to fit, just waiting on 3" exhulst solution then that will be my lot.
Currently got kkk26/8
80lb injectours
3bar fpr
Dpw
Barks ecu / map
Barks app to mointer and log afr e.c.t so no need for stand alone gauges
Uprated intercooler
Cone filter
Apexi ebc
I don't mind waiting and get a new turbo, really just want 2 do this once. Just thought I would ask
Still 2 fit
Bosch high flow pump
3" fab speed down pipe.
Specs
Compressor wheel:
Inducer 55.72
Exducer 82.43
Turbine:
Inducer 60.64
Exducer 69.82
80lb injectours
3bar fpr
Dpw
Barks ecu / map
Uprated intercooler
Cone filter
Apexi ebc
Still 2 fit
