Turbo Auxiliary Water Pump
- Thread starter scam75
Dan944t
i bought one from germany i think 3 years back ,..but cant remember what company now.
i believe it may have been £130 all in ???
im on holiday but if i return and your not sorted by then i will have a look at mine and see if i can figure anything out from the part numbers ect
JMG tried to reseal mine but it didn’t work and i found it to leak so bought this replacement
sorry can’t be of more help
Dan
scam75
Well-known member
OPC wanted £467 + vat, tidy mark up there on a spade connector!
Stuart
Waylander
https://www.ebay.co.uk/it...artemis&media=COPY
scam75
Well-known member
Waylander said:looks like the plug for that is a Junior timer plug, you can buy those as a kit cheap as chips, and it will do a nice clean finish job
This is not quite right on arrival. There are 2 raised splines on the outside of the pump connector which the plug doesn't fit over. I could just cut it to suit I suppose and it will probably slide on and be fine. Not sure exactly what connector is the correct one. Had a quick google but didn't get anywhere.
Stuart
scam75 said:This is not quite right on arrival. There are 2 raised splines on the outside of the pump connector which the plug doesn't fit over. I could just cut it to suit I suppose and it will probably slide on and be fine. Not sure exactly what connector is the correct one. Had a quick google but didn't get anywhere.
Stuart
You can get the genuine connectors and terminals from Porsche - I ordered the connectors for my wing mirrors some time ago and don't recall them being expensive. I think the metal pins were pennies. There is a whole section in PET showing all the connectors.
scam75
Well-known member
Eldavo said:Can’t remember if I cut down the splines on the pump or cut off the plug and used spade connectors - can confirm later this week when I get my car back.
Thanks.
Looks like I can probably just cut off the flat bit from the junior timer plug that goes over the splines and it should still click in and be held by the clip no bother. I decided to wait until with my mate at the garage before I started chopping it to make sure that's the best plan! Worst comes to the worst 2 insulated spade connectors attached to the loom would suffice but would be nice to use the plug.
Incidentally does anyone know if the original pump/wires are marked + and -? Or what colour is what? The new pump connector has this marked on it.
I'm amazed that this new £47 Bosch pump is absolutely identical bar the connector and Porsche want over £500 for it. Well, not really amazed actually lol but it is an utterly ridiculous mark up!!
Looking at it you could probably also remove the base of both pumps with the connectors on and swap them round. Just held on by lock tabs by the look of it. Bit of soldering probably all that's needed. I shan't bother with that idea though, much simpler to alter the loom a tad and look tidy enough!
Stuart
