Tom
I recently noticed some transmission whine which seems to have got louder over the last few days - it's hard to tell really, perhaps I was turning the stereo up to compensate or maybe its an old noise that's got louder . Whatever, it is now at the "this sounds like it might get expensive" level and the speedo has also gone mad, which doesn't seem to be a coincidence as you will see below. Do the following symptoms ring a bell with anyone?
I've owned the car for 8 years of daily use and it has covered about 101k to date, so I'm sure this noise isn't "normal".
- Whine similar to an old fashioned gearbox - think Inspector Morse Jaguar S-type
- Pitch depends on road speed, not engine speed
- Noise only heard when engine is pulling (reduces if not accelerating, stops if decelerating or clutch disengaged).
- When changing gear, the noise is heard briefly as you pass through the gate.
- Here's the strange bit, which may indicate the something to someone: The speedo misbehaves in sympathy with noise - drops to zero if throttle closed, wiggles madly when engine the noise is heard (under the conditions previously described)
- No sign of any leaks etc.
- Gearchange and clutch feel completely normal.
