TQ: Running without alternator
- Thread starter PaulHere
vincematthews
ORIGINAL: PaulHere
Question from a member:
Is it possible to drive a 2.0 engined 924 a short distance (about a mile) with no alternator?
If the battery is good (fully charged) it should be possible to start it and drive that distance.
Without an alternator and therefore a 'fan' belt fitted, the water pump will not be turning but unless its a very hot day it shouldn't overheat in that distance.
I can't see there's much difference between this and the situation where the red alternator warning light comes on when you're driving along (showing you the battery is not being charged).
You then know you've only got a few miles (or less at night) before the battery runs flat.
As vince stated, the only issue is if the water pump is being turned.
