TQ: Heater fan switch
PaulHere
Phil Grapes has a problem with his 1984 2.0
Heater fan will not run on any switch position, any suggestions? Many thanks.
Even when "off" the fan has an unswitched feed. The earth return is via three resistors which are sequentially by-passed by the rotary control to give speed variation so it should run all the time, but ever so slowly in position "0" If I was him I'd check fuse 9 (25A) and the relay. Haynes gives it as number 8, 3 in from left bottom row, but Haynes is based on a srtip down of a '78, 4 speed U.S. spec car and there is no guarrantee the UK wiring daigram is the same. I know for certain that the intermittent wiper relays do not correspond. It is nearly three in the morning so excuse me if I dont dash out and have a look at mine.
