My car has a squeek and I think it's getting worse. I suspect in not so many miles it will really start screaming. Occurs when off load and the shaft in the torque tube is spinning. So when sat in idle with the clutch up it squeeks but stops when you put the clutch in. Squeeks when rolling in gear with the clutch up or down but its only noticable when coasting. Ive been under the car and it sounds like its coming from the connection between the transaxle and the torque tube. My current thought is that its the no 4 bearing in the torque tube.
Anyone out there had this issue, fixed it themselves or paid to have it fixed? Doesn't look too hard to get the TT out but removing and re-fitting the bearings looks like it would be interesting. Sounds like its not uncommon on the turbos and when I was at Promax there was a turbo cab on the ramps having its TT re-built.
