Top Speed
- Thread starter r24
silky_spencer
Ex Club Member
I also saw 162 in my then standard Turbo coupe, measured by TomTom GPS. That's exactly as Porsche stated and I don't think it was going to go any faster.
RC18B 911 turbo
Welcome back Fen. How is it in New Zealand?
(BIG surprise was that I was racing a new 525d estate, which was also holding the speed easily, although he did back off a lot in the slight corners.)
Have to add that it felt as solid as a rock at that speed. Roof was out, wheels felt very planted, steering was as communicative as ever and the engine didn't even feel like it was breathing that hard.
My cab felt fine at 147, but then 147 isn't all that fast.
My standard Turbo felt uncomfortable at 162 (but there was a brand new 540i that had hit his 155 limiter who had to be left behind [
All of that was blown away by the RS6 which felt utterly planted and still pulling like an S2 doing 100 at 180 - the only downside was the noise as the door seals popped at 165 and the tail lights that appeared in the distance that stopped me trying for the double-ton.
You make interesting points about cab vs. coupe, both in terms of top speed (windscreen height being in the cab's favour, but the shape of the roof being against it) and stability at high speed. How did the cab handle in comparison with the tin-top? I have heard some people say that it is every bit as good, due to the double-skinned floor, and others say that it isn't a patch on the hard-top as it is simply too heavy and wobbly. (ETA: Actually, I've just read your comments on another thread about cabs and I think the question is answered there - thanks!)
Interesting comments about the RS6. I'm surprised by the door seals comment - you'd have thought that in a car designed to do that sort of speed, they'd make sure that the whole car would take it. What's the rated top speed of an RS6?
I guess you would class the double-ton as being genuinely fast? [
I say 147 isn't that fast because so many cars can go that fast, but then getting to even 157 is a big feat; anything over 150 seems to be pretty hard won.
The first generation RS6 was supposedly restricted to 155. When they were new the magazines reckoned the limiter was "soft" and more like 170-175 was available. When remapped they are usually derestricted and I believe they are geared for 205 or thereabouts if they could hit the redline in 5th. I have heard of them doing 190s but never a claim of 200+, though there is speculation as to them maybe being able to get there.
I would consider the double-ton as fast. Even my speed-freakiest mate has only seen 189 (in a 993TT).
ORIGINAL: RC18B 911 turbo
Sorry I didn't mean to ignore you Jon. NZ is great, absolutely no regrets whatsoever. I guess there are a few things I might miss, but there are a lot more that I'm glad to have left behind.
Is your car at T&T?
ORIGINAL: Fen
The cab has nowhere near as good handling as the coupe. I once missed my intended line on a bumpy corner by about 3 feet (admittedly with 18s on it) simply because it "walked" wide. It was a much nicer car with the 16s on it, but it still could shudder on a big bump.
Welcome back to the forum Fen.
For those who may not already know, Steve Kevlin defended and won his PCGB racing champion title in 1990 in a S2 cab (he won the same title in a coupe in 1989). He must be a very good driver then if the Cab is not that good enough[
berg944
Decent S2 - £4k
Petrol to get to Autobahn - £300
Winning the argument - Priceless
Body bag - Cheap as chips
In a 20 year old car!!!!![
Hope you lot do your own maintenance, I would not like to put that responsibility on anybody else.
Mike[:'(]
berg944
Any reason why a 20-year-old car shouldn't do a decent top speed?
More to the point, would you want to do a decent top speed in a 20 year old car, unless you have done the maintenance yourself and have the piece of mind to know everything is working as it should.
I have driven many 944's that I would not have been happy going fast in.
Our cars need TLC.........or a big hammer if its a bent floor pan[
Mike[:'(]
I have driven a number of 944's, but I had complete faith in mine at that speed. No concerns at all.
