Has anyone ever replaced with stiffer springs? Or just replaced with std springs and had an improvement?
I've noticed I need a very slack throttle cable to ensure tps switch is actuated and throttle valve is fully closed... Cable runs smoothly and easily... Thought perhaps a stiffer spring might help.
Side question, has anyone replaced std throttle valve on the turbo with a bigger valve? 56mm at the throat but intake is 62mm
