EddySpaghetti
Hi!
This may be the lamest post I ever have to make, but I have to ask if anyone else has had an issue with their throttle sticking open?
Mine seems to have been getting worse the last couple of weeks and tonight I looked a total prat sitting at traffic lights with the engine screaming away while I was trying to hook the throttle pedal back with my foot.
I'm nota at all used to the 'hinged at the bottom' throttle pedal, and the issue I have is with it, and the throttle arm above it 'over-centring' and getting stuck at full throttle. The problem is bad if you are stationary, and get cought like I did this evening, but its also starting to impact my enjoyment of the car because I can't control it properly - it seem the point in travel that the pedal starts to lock up is exactly in the zone wehre I need to be to control the car in turns...
Anybody had this, is it common? Any idea on fixes? - I'm beginning to worry its a feature of the bottom hinged pedal
Final thought: Anyone tossing up between an S2 and a Turbo should get the Turbo SE - If only because it has the 10 speaker stereo you need to drown out the diff noise. Seriously - I had the oil changed for 70w140 today and if anytihng the noise is louder!
