After 2k miles with my 992 Turbo S, I am pleased to report I am very happy with my purchase. [
It is prodigiously quick. has a well appointed cabin, good front end and long journeys are a breeze. The back is slightly skippy but should be resolved once the chassis alignment is adjusted next month. AND I am currently returning around 28 mpg too - must be getting old or not driving fast enough!
It's the electronics that get me. I'm starting to master the PCM now but I can't say I'm entirely proficient with it as yet.
What gets me is the diamond buttons cannot be programmed to control the stop/start function. It has to be accessed from the PCM unless it is set up within the Individual mode. It's not the same in Macan, where it can be set on the steering wheel button and, when I forget to switch it off initially, I can do so easily before the engine dies at the first traffic jam.
After some initial hiccups, Homelink works fine. Mine is programmed geographically, so the menu hits the screen whenever I drive up to the house and I can then easily operate the gates and both garage doors. However, when entering the garage and the parking sensors go crazy, it becomes very difficult to get back to the Homelink screen again in order to shut the garage door.
The radio has to be selected each time otherwise Apple Play becomes the default setting.
Keyless entry - touch sensitive door handles are erratic. Sometimes they pop out, sometimes not. Locking is a bit of a lottery too. Touching the dimple in the handle often results in nothing happening at all and I then have to hunt around for the key to physically lock the car. By contrast, the Macan keyless locking works first time, every time.
With the car locked and the door mirrors folded in, if I walk past the car with the key on me, the car auto unlocks and the mirrors open out. The car will relock if I don't get in, but the mirrors remain fully extended.
Washing the car, key in pocket, results in the boot lid continually opening whenever approaching the front of the car. Then whenever you want it open to load luggage - it won't! [
This is all very perverse and challenging on its owner, but overall the car is worth all the hassle. [
Regards,
Clive
Regards,
Clive
