drough
I am after a bit of advice please before I contact the garage. Driving my C2 on Sunday I noticed that the temperature gauge was creeping up to the 90 degree mark. As it was a cold day and I hadn't been sitting in traffic this was unusual. When I got home the gauge had climbed higher, to about 100 degrees, however the engine definitely wasn't running hot. I turned the engine off and the gauge stuck at about 90 degrees rather than returning to 'zero' as it normally would. I turned the ignition on again and the gauge went up to almost 120 degrees before jumping around a bit, then when I turned the engine off it again stuck at about the mid-point. I am thinking that this could be the thermostat or sender unit? If so how much should I expect it to cost to replace? Thanks.
