Temp Gauge Entertainment
Yes I'm definitely thinking there is a common age deterioration issue in the gauges themselves. Because nothing else makes sense when flicking the gauge can make it behave again. And of course the problem is intermittent, so could could easily "test" ok at any given time.
Will probably never know unless we come across a brand new gauge, which is highly unlikely! There is one particular ebay seller, in fact the one I got the PCB from, who lists about 40 of the gauges albeit all of them 30+ years old. And also David L I think has 4 gauges and all his do the same..............
It must work on some sort of sensitivity in order to give an accurate reading. My guess is it lies inside the gauge or in the "receiving" holes for the rugby ball prongs.
Brand new fuel gauge and coolant temperature display unit from Porsche = £631.69 (inc VAT)
94464195304
Well I revisited this today as we had quite a lot of temp gauge dancing on the road trip, intermittent as usual and only once the gauge reaches a quarter, never misbehaves below that.
I had met up with Rob (Crank Case) from TIPEC forum before the trip and he kindly sent me a spare gauge, rugby balls and dash bulbs. Alas the gauge did not survive the posting despite what can only be described as a first class packaging job. It will need soldered back together as the 2 blobs of solder holding the round tin on the back of the temp gauge have gave way. Typically this only came to light after my clock pod was out and old gauge removed! 🙈
So old gauge back in but used the rugby balls I was sent, and of course it now works perfectly. However I will be shocked if the fault doesn't return. In the mean time I will get the gauge sorted and primed ready for the next episode!
Stuart
Long time no post. It of course returned.
Left the aforementioned set-up in place. Got worse and worse, did notice ambient temp being high made it worse a lot quicker, in fact got to the the point in this heat that the gauge just rocketed skywards on ignition. Took the clocks out today, swapped the rugby ball (less clean and shiny) from the petrol gauge with the one from the temp gauge (shiny). Boom, works perfect again, as does the petrol gauge with the shiny rugby ball.
I can only conclude this issue is rugby ball related and as mentioned before the temp gauge is more sensitive than the other 3 rugby ball using gauges.
Of course we will have another relapse soon, I would so like to get my hands on some new rugby balls (I have 10 old ones in various states) to see if we can get a long lasting fix. Unfortunately I don't even know what their proper name is or who makes them. You can still buy a new clock pod cluster from Porsche, for the price of a kidney, so someone somewhere must produce rugby balls or know how to make them...................
2 x brass prongs and a wee black plastic triangle with a brass insert, can't be that hard. Brasstard things :)
Stuart
