Taycan tyre wear
carl.whitworth
hello club members, i am after some advice, my car recently went in for a service and MOT and they pointed out that one of the front tyres would fail the mot, they measured the tread depth in three places inside, outside and middle All reported 5mm of tread, but the shocking part was on the inside edge you could see the cords in places. Porsche told me this was common as the car lowers when you drive it putting the wheel alignment out...!!! the car tracks in a perfect straight line, does not pull to either side and i do not drive it hard.
Thoughts please, is this just a garage trying to fob me off, as they did the alignment four months earlier...! or is this a thing..?
Sounds like the toes is out. Did you have the service and MOT done at an OPC? I'd get a geo done specifically for the Taycan model you have, that should allow for the lower suspension. Your OPC should be able to do this for you but it most probably won't be cheap.
Dan
Dan
thanks Dan, it was the OPC that did it dec 24...!
The vehicle height change at speed should not make any significant change to the wheel alignment or cause tyre wear - otherwise Porsche would have major extra warranty issues.
As said above, its much more likely to be a tracking issue (toe-in /toe-out).
It won't have changed significantly since they did their check 4 months ago UNLESS the car has been kerbed / hit a bad pothole. Do they have the record of the check 4 months ago ? Did they actually change the toe-in then or just check it ?
I had this on my Taycan. First set of fronts actually deflated by wearing through the inner shoulder whilst every other part of the tyres looked great. I had them replaced, got the alignment done and the same thing happened 15K miles later! I ran it in sports plus all the time and do believe that contributed to the problem.
