Suspension
- Thread starter Guest
KW users, do your rear springs clonk the bodywork if you go over rough surfaces? The nearside Gaz Gold does it reliably, but then I was clearly advised about that and just put up with it.
diabloam
944 man
GAZ can supply basic, adjustable and remote reservoir kit for 931, 944s1 early and 944s1 late, both pre and post '87 series two cars, 944Turbo/944S2 and 968.
If I can find the mans name I will let you know.
Simon
Neil Haughey
ORIGINAL: 944 man
If you speak to GAZ directly then youll get very different pricing. I cant remember the fellows name off the top of my head (David Something, I think...), but you will find the prices extremely keen and his technical knowledge reassuring.
Simon
Do you mean Dave Lyons?
Trevor68
ETA: Mine was already re-indexed at the rear.
944 man
ORIGINAL: Neil Haughey
Thats the fellow. I had written down Dave Lyman, but I wasnt confident that Id heard his surname clearly. That was my opinion of him from the couple of conversations Ive had with him: would you agree?
Neil Haughey
Are the Gaz GHA coilovers available for 944 as I can only find them listed for 924 and if so does anyone have them fitted?
Thanks, Alan.
I also have poly bushes to fit on front arm and castor mounts.
Any tips on what i can spray on to free off seized bolts prior to starting this work?
Thanks, Alan.
Hilux
Plus Gas or make your own from paraffin and diesel
Brilliant stuff, badly corroded nuts etc soak a few times over a few days and if stubborn a bit of heat always helps
Neil Haughey
Also not trying to teach you how to suck eggs but remember constant pressure on a bolt and don't jerk at it or it will sheer or round.
