pae
OK, it's suspension time now. I'm no expert on suspension, and don't have much history on my car, so let's start with the assumption that it's all original quality (and probably age [:'(]). And also the 924S doesn't have blistering performance, but I'd like it to feel more solid. Oh, and we're talking road here, not track set-ups.
Where do I start to improve/tune the suspension? The car feels quite 'lively' on poor-ish surfaces at speed (for example, when I'm changing lanes on a dual carriageway across a bad surface - not potholes, but where you get those ripples along the surface). It seems to 'bounce' across the bad bits.
This might be as simple as tyre type or pressures, but I'm not at all experienced in suspension diagnosis. Tyre pressures I can experiment with easy enough (and I've plenty of bad roads to try it on [
]) but what bits change what exactly?
Should I uprate (or at least renew) the shocks? It doesn't seem to 'bounce' when you push down and release each corner, but then again it's pretty stiff in the first place. And how much 'bounce' is OK?
What effect will different ARB's have?
What about lowering?
Help !!!!!! - where do I start? I am trying to organise for a 'local specialist' to have a drive and advise if (a) what i've got is worn out anyway and (b) what are the most sensible improvement steps to take.
advice appreciated..........Phil
