My BoV is the recirculating type, I can't hear it working from inside the car but it seems to do the job. Coming on and off the throttle is almost as instantaneous as before.
I couldn't resist the thought of more boost (yes it is contagious) so in the morning I tightened the belt as much as I dared. Sadly it hasn't made any difference, it's not I'm unhappy with what I've got but I would just like to make sure it's running at its optimum first. I'll have a checkover for boost leaks as a matter of course. I could always be tempted to fit a smaller pulley to up the boost if I feel the need [
The first track session went better than expected, the car was definately quicker everywhere than before (and I was able to drive it home too [
]). A few issues arose but nothing major:
-The dipstick is being forced out, the first time it did it it made a right mess of the engine bay [
] the subsequent times I was lucky that it had just risen a small amount when I checked. I seem to remember Rick runs his car with the oil filler cap loose, I wonder if it's for this reason?
-Something odd is happening to the boost pressure, Paul noticed that in 5th the boost is not reaching the same peak as in 4th, I'd noticed how the power dropped off but had never been able to watch the boost gauge whilst going at these sorts of speeds. I really can't understand this, any pointers would be a great help.
-Engine temps are getting a bit too high (I was warned this would be a problem!), I think it's the coolant and not the oil that's causing it. I think it's the warm air coming off the intercooler before going onto the radiator that is causing it.
I suspect this will be the most difficult problem to solve, but thankfully I was able to get quite a few laps in before having to back off (and the temps drop almost immediately, which I think confirms this theory). I do only have a single fan fitted and not the twin setup of the S2, so I might consider changing it. I'd rather not replace the IC (I'm rather doubtful that a 951 one with fit under my badge panel anyway). I already have a larger radiator fitted, so I might look at the general airflow in and out of the radiator to see if there's any gains that can be made there.
