I have recently developed a problem with my sunroof !
With the keys in the ignition but the engine off the pins will releace as normal, but will not engage ! If i then engage the pins manually from the motor, with the ignition turned on the pins will then return the roof back to the locked postion but will not raise the roof ?
I have taken apart the switch and cleaned it, all is fine with the switch, i have checked the relays on the roof motor again all seams fine, the wiring also seams fine although i have only visually checked it at this point. Any body ran across similiar problems ??
Marc
Marc
