Chaps,
A slightly odd one. I'm throwing it in here more out of hope than expectation ...
The sunroof on my S2 is misbehaving. I have tried smacking its bottom and putting it on the naughty step, but it hasn't helped.
It won't open. Reliably. Sometimes it won't open at all (press the button and nothing happens - no spinning from the motor, nothing). Sometimes it will open a little, but stop half-way. Sometimes it will not open, but will open if you try it a couple of minutes later. Sometimes it will open a little, and if you release and re-press the button it will open fully.
It will always close properly, when required.
My guess is either an intermittent bad connection, or something rum is happening with the microswitches. Either way, I need to take it apart and diagnose it properly. Probably with a wiring diagram in my hand. (And - thankfully - it's not a major fault, neither is it likely to be difficult or expensive to fix, I am hoping.) But has anyone seen this problem before, and therefore have suggestions as to what is (or isn't) happening?
All suggestions welcomed - thanks.
