sunroof issues
j4mou
I am trying to remove the roof so I can clean the water tubes out, but it wont retract the arms so I can remove the roof, the roof opens but it wont do the reverse operation, is there a fuse/relay that could of gone or am I doing something wrong?
James :)
Check the cable where it enters the sunroof motor in the boot. The outer sleeve used to pull off mine and I had to secure it with a couple of jubilee clips.
Have a look on Clarks, they have a very good write up on the sunroof.
Here:
http://www.clarks-garage.com/
Garage Shop Manual then Sunroof
wow thats a handy website thanks! looks like its the main sunroof relay. where do I get one from? [:(]
was going to suggest front microswitch as I think mine did similar when it was faulty, but a long time ago so could have been opposite - down not up.
ORIGINAL: j4mou
How many times have I told you about Clarks Garage?
