Maverick76
Hi everyone, glad to have found you, hope someone can help.
I bought a Porsche 944 S2 cabriolet back in 2002. It was my everyday car for 6 years until the clutch packed up.
Doing things on the cheap, I decided to replace the clutch with the help of a friend (who is a mechanic) on my driveway off of axle stands.
The clutch part went fine I'm happy to say, the part that went wrong was me trying to change parts on the rear sub frame.
A few months before the clutch broke I had some knocking noises and I was told it could be spring plates, so while we had the gearbox out I thought it was a good time for me to change them before we put it all back together the following day.
Unfortunately, I just unbolted the spring plates without marking their positions, so when we put everything back together and lowered it off the axle stands my tires were up in the wheel arches and the back end of the car was nearly on the floor.
Seeing as it needed a lot of rust work to be done, as well as taking the gearbox and everything else back out to adjust again, it was put into the garage until I could save up for the bodywork.
Here we are 12 years later, and I am able to get things going again.
The car had a battery connected a month ago and after fitting a £25 fuel pump from eBay, fired up straight away and is ticking over.
I have managed to get one second hand front wing (without any rust) and some new side sills and rear quarter panels to put in.
The next thing to do is tackle the 2008 mistake and correct the ride height at the rear end, but before I dismantle the back end again to get the subframe out I have questions.
Once I have the subframe off and laid on the floor, is there a factory setting measurement to set up the spring plates onto the torsion bar?
I really don't want to put it back, then find it needs further adjustment and have to take everything out again and blindly hope I get it right.
If you know of any information on this subject or any manual that I can purchase to make this job any easier to get done, I would seriously appreciate it.
