Help! I have some sort of oily leak all over the lower end of my front struts, tie rods, wishbone (trunion) edges and around the 2 central rear nuts securing the (brake servo and rack) undertray. Slightly more on driver's side and also possibly up the oil cooler tubes before they pass into the front vent area. Surely a steering rack leak, especially as the reservoir is on the minimum? BUT I cannot see any sign of it when I remove the undertray, even with the engine running. The rack is bone dry apart from a tiny dampness at the bottom breather(?) plug and nothing around the bellows each side. The inside of the undertray itself is bone dry apart from the extremities and the rear fixing dimples. Perhaps racks only leak on full lock? The oil cooler tubes look suspiciously corroded in the wheel arch but no visible signs idling with a hot engine. Car has recently passed its post-Winter MOT so I think this has appeared very suddenly or they'd have failed it on apparent front strut leaks or perhaps steering rack faults.
Any advice or experience welcome please as I'm keen not to start potentially very expensive repairs until I am sure what it is! [
