944Scott
Guys im after some suggestions.
In attempting to fit my de cat pipe one of the studs on the pipe from the turbo has sheared off. As their is some stud left I had thought about halving the thickness of the flange on this side to allow me to use the remainder of the stud except the thread that is left is stretched. I have tried to use a die on it without success and I have even tried making it a smaller diameter for a smaller die but to no avail.
Im undecided on the next course of action, do I try and grind the stud flat then try to drill and tap a hole with it in situ (crossover pipe is also still in place) or do I aim to remove the exhaust pipes off the turbo ( I am loathed to remove the inlet manifold after fixing an inlet leak) sod's law says I will end up yet more bits snapping, when I originally removed the wastegate several bolts snapped [
I would welcome your thoughts.
