Strange noise
- Thread starter sr.944man
Kongsodoken
so I have a strange woo woo woo noise from the rear its speed dependent and not engine related still there if I dip the clutch....it starts after about 3 miles and disappears after 10 miles
any guesses ?
Monkeythree
CV joint?
I'm assuming these are all new on your car so shouldn't be doubted but if there's a noise, there's a noise!
Kongsodoken
starnge that the noise is intermittent and very loud .....but only lasts for a few minutes and doesn't come back till every thing has cooled then warmed up
Monkeythree
Kongsodoken said:Yes new OEM bearings. The cv joints are not new but greased and they looked OK
Are the CV joints correctly orientated? There is a circumferential groove. I can't remember whether the groove should be towards the outside or the inside without checking but a starting point would be to check that the left side mirrors the right. I can stick my head under mine tomorrow and check if you want.
peanut
if you coast round the bend in neutral you'll eliminate the engine or transmission being the source of the problem.
Kongsodoken
ready with the phone to record the noise
Kongsodoken
with so much knowledge on this forum they say posting on here is the best way to solve 944 problems ...Wow it works mine sorted without the need for any tools[
